Finally made it to 5th gear :) |
Kerrys914 |
Nov 17 2003, 07:57 PM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
Took my 914 to work today. On the way in I took the longer and slower route. It has been doing fine the 4-5 times I have driven it to work.
I decided today to hop onto I295 and give her a go (IMG:style_emoticons/default/MDB2.gif) As I shifted into 5th the engine died (2-3 seconds) and then picked back up. It ran fine for the next 5-10 mins. I then slowed down and merged onto I64..Back upto 5th gear and the same thing happened..Tach goes to zero and the engine dies again (2-3 seconds) and then picked back up???? Any thoughts? I guess I will try tomorrow and see if It does it again. (IMG:style_emoticons/default/headbang.gif) Cheers Kerry |
redshift |
Nov 18 2003, 08:43 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
When I get electrical gremlins, I go postal, and clean every contact, and every connector, in every system, nose-to-tail...
I use cans of contact cleaner, emory boards, paper, toothbrushes, toothpics, q-tips, and this dielectric grease that comes in a little tube.. and loses the label when the glue solves.. (IMG:style_emoticons/default/smile.gif) Gluggling, and 'feels like ignition cutouts' can happen with bad spark wire sets, TPS, bad fuel pressure, iffy sparks, wrong heat range plugs, misgapped anything, broken advance, MPS misdialed, bad gas... combinations... - (IMG:style_emoticons/default/welder.gif) - I just wanted to use that. I missed the frontend of this.. I think. M |
Lo-Fi Version | Time is now: 11th June 2024 - 08:24 PM |
