Something not right w/ clutch, Help needed from V8 guys again |
aircooledboy |
Jan 1 2005, 01:46 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Well, pulled the trans yesterday. Went very well, thanks for the pointers. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
Hi-evah, something is just not right with the clutch assembly. When I first mated the trans back to the engine in august, I noticed there was no free travel in the clutch fork. I even pulled it back apart to male sure noting had gotten caught. Once put back together, I had to tighten the clutch cable to get the fork off the back of the opening int the bell housing, or the fork would chatter against the housing with the clutch out. Well when I took it apart yesterday, I find that the top of the pressure plate is hitting the fork, which ground a groove into the fork. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Attached image(s) |
wbergtho |
Feb 19 2007, 01:32 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
KEP has very good customer service. They seem to understand that by keeping the customer happy (they actually screw up once in a while...they are people too) they will always have plenty of business. Perhaps your clutch package is simply worn out and it is no ones's fault. I'm not sure of the mileage you have on those parts. I would strongly recommend you ask KEP what they can do for you and you might be surprised (pleasantly) at what you get back from them. I have alot of experience with them and I can say they aim to please.
Bill QUOTE Send the pressure plate and disc back to Kennedy engineering in Sothern CAL. They kinda like to see how their products performed. They will rebuild it and they may even have some pointers on why it failed. This will save you some money and give you some expert knowledge and recomendations. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:51 AM |
