One Headlight Stuck in Up Position, What is the solution? |
nick mironov |
Feb 21 2007, 07:55 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
I searched and read the topics I found on the subject. The topics mostly describe how the headlight motor system works. None describe what the typical problem is and how to fix it.
In my case, (1975) the headlight motor itself works. The right side headlight always comes up, but recently does not always go down. Is there a problem with the motor, a relay, something else? There is no obvious adjustment. Nick |
Chris Pincetich |
Feb 21 2007, 08:04 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Your trusty Haynes manual shows how to lower it in a jam. There is a non-obvious knob on the back of the motor, turn the knob A LOT and the light raises or lowers. The first time(s) I did it, I accidently unscrewed the knob...it works going either way.
Swap the relays side to side and see if that identifies a bad relay. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 11:08 PM |
