C2 5 Spoke, best dimensions/tire size combo. |
BiG bOgGs |
Feb 24 2007, 07:59 PM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
While I am looking at a 914 that has a 5 lug conversion, I am trying to look down the road towards the look I might like to have for it. I have always liked the look of the C2 Porsche wheels. The 914 I am looking at has Fuchs on it right now, and had the lip of the wheel well hammered flat, as well as smaller tires. I want to have taller tires on it for the regular highway driving that I do. Which width and backspacing and tire combo will give me a tire diameter close to or a little bigger than stock with out having to do any body massaging?
I know I can check the tire size speedo calculation on the board, but I need experenced opinions on what wheel width/tire size combo will fit in stock wheel wells. Jim (IMG:style_emoticons/default/blink.gif) |
Mueller |
Feb 25 2007, 11:01 AM
generally you are stuck at using a 7" wide rim with 205's unless the rear fenders have really been tweaked...
if using a 7" rim with a 55mm offset, a 20mm spacer would place the rim nicely in the rear, I;d opt for 35mm spacer in the front overall tire diameter is dependant on how low the car is, best bet is to use this tire cal. = tire cal. a 205/55/16 works |
Lo-Fi Version | Time is now: 10th June 2024 - 06:17 AM |
