| 914Sixer |
Mar 5 2007, 07:31 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,466 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I am going to build a 2.0 motor with a little help from Jake and Len. I had a 71 1.7 complete motor to use the case. I spent 5 evenings disassembling the motor and cleaning the case to use. This afternoon I was admiring how clean the outside of the case was, so it was time to start on the inside then it hit, WTF! One side of the case has the U shaped shelf for the oil baffel and the other side does not! I took some pictures of the halfs. Has anyone else found this ?
I have an additional 73 EA case 1.7. It looks like I will be pulling it out of the parts car this weekend and starting over. Attached image(s)
| Bleyseng |
Mar 5 2007, 09:13 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
It should have a case number stamped on the flywheel area like 245 on both halves or its a reman.
914Sixer 1.7 case differences Mar 5 2007, 07:31 PM
davep It could be a transition engine using up case halv... Mar 5 2007, 07:38 PM
914Sixer It was an Unstamped case. I almost sure it had ne... Mar 5 2007, 07:52 PM
davep Unstamped would tend to indicate a reman engine fr... Mar 5 2007, 08:15 PM
914Sixer OK, I checked the case halfs at the top of the cas... Mar 7 2007, 09:45 PM
davep Okay, so it is a transition case, half old & h... Mar 8 2007, 06:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:43 AM |
