Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
It was a lovely day today in Rockville MD., so I took advantage of the situation & decided to get some work done on the 6, as well as explore her little better. The only surprise was a good one... no additional rust discovered & I have a "K&H dialable" brake proportioning valve installed. The PO told me it was time for an oil change & I had scored a genuine owners manual for the 6 on eBay & had been reading. Nine & a half quarts every 3k mi. & the tranny every 6k mi.? I wanted a fresh start so I did both. The engine took me 10.5 quarts... I don't have a 2.0 I have a 2.7... I hope that's normal. Changed the filter & cleaned out the strainer... all looked clean or no debris. Bottom of the engine looked dirty though, I think I'm leaking from the strainer & the oil cooler... I will be investigating. I ploped a full 3 into the tranny & got the plug in while it was still gushing out. While I was down there I decided to install a rear sway bar. When I purchased the car I noticed it used to have a rear sway bar but it had been removed for some reason. This made installation a snap. Hardest thing to do was take off the muffler... it is big & somewhat heavy. Tomorrow I clean out the air filters, lube my linkages & am going to check the plugs to see how they are. After that... (IMG:style_emoticons/default/driving.gif) . I find myself enjoying working on her a little too much & really need to drive instead (IMG:style_emoticons/default/laugh.gif) !
(IMG:style_emoticons/default/cool_shades.gif) |
Johny Blackstain |
Yes, level surface, poured in 9, stock tank, fired her up, let her warm up 10 minutes, however I then did as the manual said & shut it off & checked it. Took another 1.5 qt. to get it up to the fill line.
Lo-Fi Version | Time is now: 18th September 2025 - 06:15 PM |
