> 10.5 quarts!, working on the 6
Johny Blackstain
post Mar 10 2007, 07:20 PM
It was a lovely day today in Rockville MD., so I took advantage of the situation & decided to get some work done on the 6, as well as explore her little better. The only surprise was a good one... no additional rust discovered & I have a "K&H dialable" brake proportioning valve installed. The PO told me it was time for an oil change & I had scored a genuine owners manual for the 6 on eBay & had been reading. Nine & a half quarts every 3k mi. & the tranny every 6k mi.? I wanted a fresh start so I did both. The engine took me 10.5 quarts... I don't have a 2.0 I have a 2.7... I hope that's normal. Changed the filter & cleaned out the strainer... all looked clean or no debris. Bottom of the engine looked dirty though, I think I'm leaking from the strainer & the oil cooler... I will be investigating. I ploped a full 3 into the tranny & got the plug in while it was still gushing out. While I was down there I decided to install a rear sway bar. When I purchased the car I noticed it used to have a rear sway bar but it had been removed for some reason. This made installation a snap. Hardest thing to do was take off the muffler... it is big & somewhat heavy. Tomorrow I clean out the air filters, lube my linkages & am going to check the plugs to see how they are. After that... (IMG:style_emoticons/default/driving.gif) . I find myself enjoying working on her a little too much & really need to drive instead (IMG:style_emoticons/default/laugh.gif) !
(IMG:style_emoticons/default/cool_shades.gif)
RickS
post Mar 10 2007, 08:44 PM
Make sure you check the oil level with the car at regular operating temps. It should read halfway between the add and full marks.
Johny Blackstain   10.5 quarts!   Mar 10 2007, 07:20 PM
mikez   914 owners are divided on the need for a rear sway...   Mar 10 2007, 07:26 PM
Aaron Cox   you did check the oil level while running and on a...   Mar 10 2007, 07:27 PM
Johny Blackstain   Yes, level surface, poured in 9, stock tank, fired...   Mar 10 2007, 07:40 PM
TimT   needs to be running for a proper oil level check   Mar 10 2007, 08:21 PM
Johny Blackstain   I guess I'll just check again, while running, ...   Mar 10 2007, 08:33 PM
Cap'n Krusty   I guess I'll just check again, while running,...   Mar 11 2007, 09:34 PM
RickS   Make sure you check the oil level with the car at ...   Mar 10 2007, 08:44 PM
Johny Blackstain   :dance: . :shades:   Mar 10 2007, 08:47 PM
Rotten Robby   There are maybe three "decent" oil filte...   Mar 11 2007, 01:26 AM
Johny Blackstain   Warm and running... I know what your thinking but...   Mar 11 2007, 01:27 PM
Elliot Cannon   I've always found it difficult to check the oi...   Mar 11 2007, 01:45 AM
Johny Blackstain   I've always found it difficult to check the o...   Mar 11 2007, 07:04 AM
SLITS   I've always found it difficult to check the o...   Mar 11 2007, 09:18 PM
Racing916   Johny, Are you going to the Hershey, PA swap meet...   Mar 11 2007, 08:43 AM
Johny Blackstain   Johny, Are you going to the Hershey, PA swap mee...   Mar 11 2007, 11:38 AM
mikez   I have a cosmetically challenged set of 914/6 heat...   Mar 11 2007, 11:47 AM
TimT   Here is a replacement filter cost is only about...   Mar 11 2007, 12:55 PM
Johny Blackstain   Well I went in & fired her up... I hate cliche...   Mar 11 2007, 01:45 PM
Cap'n Krusty   That's not the line, that's the handle. T...   Mar 11 2007, 02:43 PM
Johny Blackstain   That's not the line, that's the handle. ...   Mar 11 2007, 03:53 PM
Porsche Rescue   I have always used the lower "hook" over...   Mar 11 2007, 05:32 PM
- Lo-Fi Version Time is now: 18th September 2025 - 06:14 PM
