> why does my head lights go up when I push in my light switch?
buck toenges
post Mar 11 2007, 11:14 AM
I have looked at the diagrams, hooked up the light switch accordingly and still my head lights go up when I push in my switch in and they go down when I pull the switch out!
I have tried different headlight relays and still the same thing. Where do I go from here?
1) could switch be bad?
2) Could the harness get mixed up at? the fuse box? the head light motors them selves? At the relay connection? Could I have something hooked incorrectly other then the switch itself?
It is a 10 pin switch and the car is a 72.
Thanks,
Buck
davesprinkle
post Mar 11 2007, 11:35 AM
Hi Buck,
This might be the result of incorrect assembly of the actuation arm on the motor shaft. I had this same problem when I reinstalled the headlight mechanisms in my 74. To fix the problem, I just rotated the arm on the shaft by 180 degrees. Maybe this will work for you.
I should point out, though, that if you haven't taken apart and reassembled your mechanism, this is unlikely to be the cause of your issue.
Good luck.
-dave
- Lo-Fi Version Time is now: 17th April 2026 - 05:58 AM
