> 10.5 quarts!, working on the 6
Johny Blackstain
post Mar 10 2007, 07:20 PM
It was a lovely day today in Rockville MD., so I took advantage of the situation & decided to get some work done on the 6, as well as explore her little better. The only surprise was a good one... no additional rust discovered & I have a "K&H dialable" brake proportioning valve installed. The PO told me it was time for an oil change & I had scored a genuine owners manual for the 6 on eBay & had been reading. Nine & a half quarts every 3k mi. & the tranny every 6k mi.? I wanted a fresh start so I did both. The engine took me 10.5 quarts... I don't have a 2.0 I have a 2.7... I hope that's normal. Changed the filter & cleaned out the strainer... all looked clean or no debris. Bottom of the engine looked dirty though, I think I'm leaking from the strainer & the oil cooler... I will be investigating. I ploped a full 3 into the tranny & got the plug in while it was still gushing out. While I was down there I decided to install a rear sway bar. When I purchased the car I noticed it used to have a rear sway bar but it had been removed for some reason. This made installation a snap. Hardest thing to do was take off the muffler... it is big & somewhat heavy. Tomorrow I clean out the air filters, lube my linkages & am going to check the plugs to see how they are. After that... (IMG:style_emoticons/default/driving.gif) . I find myself enjoying working on her a little too much & really need to drive instead (IMG:style_emoticons/default/laugh.gif) !
(IMG:style_emoticons/default/cool_shades.gif)
ConeDodger
post Mar 11 2007, 01:26 AM
Apex killer!
There are maybe three "decent" oil filters you should trust. Pay for the stock one. You can find it cheaper...
Warm and running... I know what your thinking but that isn't what I said... If you overfill you will be making a mess soon. Everyone does it.
Johny Blackstain
post Mar 11 2007, 01:27 PM
QUOTE(Rotten Robby @ Mar 11 2007, 02:26 AM) *
Rob- you're right!! (IMG:style_emoticons/default/thumb3d.gif)
Johny Blackstain   10.5 quarts!   Mar 10 2007, 07:20 PM
mikez   914 owners are divided on the need for a rear sway...   Mar 10 2007, 07:26 PM
Aaron Cox   you did check the oil level while running and on a...   Mar 10 2007, 07:27 PM
Johny Blackstain   Yes, level surface, poured in 9, stock tank, fired...   Mar 10 2007, 07:40 PM
TimT   needs to be running for a proper oil level check   Mar 10 2007, 08:21 PM
Johny Blackstain   I guess I'll just check again, while running, ...   Mar 10 2007, 08:33 PM
Cap'n Krusty   I guess I'll just check again, while running,...   Mar 11 2007, 09:34 PM
RickS   Make sure you check the oil level with the car at ...   Mar 10 2007, 08:44 PM
Johny Blackstain   :dance: . :shades:   Mar 10 2007, 08:47 PM
Rotten Robby   There are maybe three "decent" oil filte...   Mar 11 2007, 01:26 AM
Johny Blackstain   Warm and running... I know what your thinking but...   Mar 11 2007, 01:27 PM
Elliot Cannon   I've always found it difficult to check the oi...   Mar 11 2007, 01:45 AM
Johny Blackstain   I've always found it difficult to check the o...   Mar 11 2007, 07:04 AM
SLITS   I've always found it difficult to check the o...   Mar 11 2007, 09:18 PM
Racing916   Johny, Are you going to the Hershey, PA swap meet...   Mar 11 2007, 08:43 AM
Johny Blackstain   Johny, Are you going to the Hershey, PA swap mee...   Mar 11 2007, 11:38 AM
mikez   I have a cosmetically challenged set of 914/6 heat...   Mar 11 2007, 11:47 AM
TimT   Here is a replacement filter cost is only about...   Mar 11 2007, 12:55 PM
Johny Blackstain   Well I went in & fired her up... I hate cliche...   Mar 11 2007, 01:45 PM
Cap'n Krusty   That's not the line, that's the handle. T...   Mar 11 2007, 02:43 PM
Johny Blackstain   That's not the line, that's the handle. ...   Mar 11 2007, 03:53 PM
Porsche Rescue   I have always used the lower "hook" over...   Mar 11 2007, 05:32 PM
- Lo-Fi Version Time is now: 18th September 2025 - 06:15 PM
