Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
It was a lovely day today in Rockville MD., so I took advantage of the situation & decided to get some work done on the 6, as well as explore her little better. The only surprise was a good one... no additional rust discovered & I have a "K&H dialable" brake proportioning valve installed. The PO told me it was time for an oil change & I had scored a genuine owners manual for the 6 on eBay & had been reading. Nine & a half quarts every 3k mi. & the tranny every 6k mi.? I wanted a fresh start so I did both. The engine took me 10.5 quarts... I don't have a 2.0 I have a 2.7... I hope that's normal. Changed the filter & cleaned out the strainer... all looked clean or no debris. Bottom of the engine looked dirty though, I think I'm leaking from the strainer & the oil cooler... I will be investigating. I ploped a full 3 into the tranny & got the plug in while it was still gushing out. While I was down there I decided to install a rear sway bar. When I purchased the car I noticed it used to have a rear sway bar but it had been removed for some reason. This made installation a snap. Hardest thing to do was take off the muffler... it is big & somewhat heavy. Tomorrow I clean out the air filters, lube my linkages & am going to check the plugs to see how they are. After that... (IMG:style_emoticons/default/driving.gif) . I find myself enjoying working on her a little too much & really need to drive instead (IMG:style_emoticons/default/laugh.gif) !
(IMG:style_emoticons/default/cool_shades.gif) |
Johny Blackstain |
Well I went in & fired her up... I hate cliche's; "once you go six you can't go back" (IMG:style_emoticons/default/biggrin.gif) . I took a photo of the culprits that can lead to false readings; see below. That 1st one gets hung up onto the tube every time. Anyway, like a true Dumb A** I checked while stone cold & sure enough it looked to be about 1/2 a qt. high. So I rolled her out into the sunlight & let her warm up. While warming up I took advantage of the weather, the warm dry & level parking lot & adjusted the new rear sway bar while she was on all 4's. Not so "Dumass" (IMG:style_emoticons/default/biggrin.gif) .
I ran her today & let's just say I think I know how Vader felt the 1st time in his little black Tie fighter (IMG:style_emoticons/default/happy11.gif) . The power & handling were phenomenal. Back end was noticeably tight... I like it. Got home & let her idle on level ground & the reading was perfect... right on the line (IMG:style_emoticons/default/confused24.gif) ? Attached image(s) ![]() |
Lo-Fi Version | Time is now: 18th September 2025 - 06:18 PM |
