> Fox Shocks install(help)
dekman
post Mar 11 2007, 05:20 PM
Cracked a header so while up on the "Stands" deceided to replace the rear 20+ yr old carrera shocks. Has anyone install Fox shocks w/remote reservoir? Any mods needed? How do you put the reservoir in the trunk w/o cutting a hole? Bolts supplied are too short.....Help! (IMG:style_emoticons/default/headbang.gif) (need to get her off the "Stands" so I can make the Route 66 Ramble!")
Aaron Cox
post Mar 11 2007, 05:24 PM
Professional Tinkerer
reservoir into the trunk?
you would either A ) have to cut a big hole for the whole reservoir to fit, or B ) cut a littler hole, discharge the gas in the shock, unscrew the reservoir, feed the hose through, reattach the reservoir and refill the shock with fluid/gas.
nice shocks.....
you can always go get longer bolts, solves that problem.
- Lo-Fi Version Time is now: 23rd September 2026 - 12:44 PM
