Type 4combo 2270 ?, extra motor |
sixnotfour |
Mar 17 2007, 12:17 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
So I bought a roller, recognized it as a pelican car , this is the motor, any good?
should I take apart and part it or sell whole, has been sitting and some corrosion in one intake port , water ? Whats it worth together ? pieces? Thanks for your input; here is the description from the pelican build thread: specs on the motor, it's a 2270 comprised of a 78mm crank, lightened and balanced rods, 96mm balanced and lightened pistons weight balanced within .5 grams, a SCAT 275 duration X 490 lift cam and SCAT lube-a-lobe lifters, straight cut cam gears, high performance springs and dual 45 Dellorto carbs. If it were a six I would exactly know what it is worth being a type 4 , I have no idea , |
sixnotfour |
Mar 17 2007, 12:22 AM
It is oil film covered now, was removed to fix oil cooler leak and has sat since.
old thread; http://forums.pelicanparts.com/showthread....ighlight=skline Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 10:57 AM |
