Sick running engine, FI Problem? |
xperu |
Mar 17 2007, 10:03 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I have a 73 1.7 with FI.............. I am having problems when accelerating, the engine hesitates or jerks severely and will smoothes out after driving down the road, but I can feel the periodic missing. I had the car checked out for a possible electrical short and the electrical checked out good. I would appreciate your expertise and any suggestions or list of possible components that might be the problem.
I share the compassion for my 914, but reliability and to much garage time to the point of cerebration creeping into my mind; please help . |
jk76.914 |
Mar 17 2007, 11:32 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Mine was a lean miss. Happened around 3000-3750 rpm, then smoothed out. I finally verified it by tweaking the fuel pressure up to about 32 PSI. That was just to test the theory, because that richens the mixture across the board. Finally replaced the fuel injectors.
You can also try a ballast resistor in series with the cylinder head temp sensor. If the miss goes away, you've confirmed a lean miss. 10% ethanol in our fuels doesn't help. If you're running right on the edge, mixture wise, with gasoline, you may be too lean with the gasohol. I haven't been able to prove anything either way, since I can't get pure gasoline anymore here in the Northeast, but with no lambda feedback to correct for it, it doesn't help. Jim |
Lo-Fi Version | Time is now: 8th June 2024 - 05:31 AM |
