Pre-Cut Roll Cages, Is there such a thing? |
soloracer |
Mar 16 2007, 04:53 PM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
I know that Autopower makes bolt in cages but is wondering if there was such a thing as pre-cut, pre-bent and weld it yourself cages. Anyone ever heard of such a thing? If so, where would I find one?
BigD9146gt |
Mar 17 2007, 09:22 PM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
solo,
My initial reaction to $4K is also a bit steep, but I would also need to know more details about what materials quoted and workmanship... cause the latter unit (99% of the time) will make or break the bank. However, you do have one key asset... your friend with the pipe bender. If you trust his skills as a fabricator, I would suggest you buy a cheap ratchet style tubing bender (JD2 "model 3" bender is what I started with and still have for doing jobs on site. Give these guys a call, they're really helpful... http://vansantent.com/tube_bending_machines.htm ) pick one up new or used from Evilbay, get the die you will need for your cage tube diameter, then sell it when your done and get a few bucks back. Shop around, figure a safe $1000 on material and a good bending tool (you should be able to pick one up for less than $600), a few six packs and pizza for your friend, your on your way. Cheers, Don. |
Lo-Fi Version | Time is now: 8th June 2024 - 11:10 AM |
