| Aaron Cox |
Mar 16 2007, 08:23 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
ok, so there are two ways to do this im told, you can make a spacer to fill the area on the stub where the dust seal on a 944 used to live, or you can lathe that off, and let the stub sit deeper into the hub-
so here are pics with dimensions...... ill have to go back and write in the dimensions.... cant read the calipers on a few. (shoulda got the digital ones LOL) the materials required. Bearing, early 911 hub, 951 stub, calipers. ![]() Bearing width. ![]() diameter of "dust seal area" and diameter of bearing area on hub. ![]() width of dust seal area ![]() width of bearing area on hub ![]() combined.... ![]() bearing diameter if you need it. ![]() |
| Luke M |
Mar 17 2007, 05:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,623 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Clay,
Which setup do you have on your six? I'm going to a 2.7rs six and would hate to have cv/spacer come apart on me. I've heard of these spacers/bolts coming loose and wrecking afew things. |
| ClayPerrine |
Mar 18 2007, 01:21 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Clay, Which setup do you have on your six? I'm going to a 2.7rs six and would hate to have cv/spacer come apart on me. I've heard of these spacers/bolts coming loose and wrecking afew things. I have the spacer and the 944 CV joints on a 914 axle. We did that one first before we (I had the help of Wes Hildreth, he was using my car for the prototype) figured out that you could machine the hubs and use 944 axles without mods. If you do this right, you won't break a joint. Those 944 CVs are beefy suckers, and you get a 6 bolt connection to the flanges. |
Aaron Cox 944 stubs on 911 hubs, the bearing spacer info you need Mar 16 2007, 08:23 PM
John I prefer the later hubs, but then you would probab... Mar 16 2007, 09:18 PM
Luke M Hey, Aaron
Is that the setup that you have on your... Mar 17 2007, 03:32 PM
ClayPerrine
Hey, Aaron
Is that the setup that you have on you... Mar 17 2007, 03:40 PM
Aaron Cox
Hey, Aaron
Is that the setup that you have on yo... Mar 17 2007, 08:09 PM
ClayPerrine
[quote name='ClayPerrine' post='876049' date='Mar... Mar 18 2007, 01:19 AM
LarryR
Hey, Aaron
Is that the setup that you have on you... Mar 17 2007, 10:35 PM
John Those 944 axles that bolt up to the coarse spline ... Mar 18 2007, 02:07 AM
Luke M Clay,
Could you break down the parts/years that yo... Mar 18 2007, 08:10 AM
ClayPerrine
Clay,
Could you break down the parts/years that y... Mar 18 2007, 09:02 AM
Luke M Thanks, for the info. Clay.
Looks like that may be... Mar 18 2007, 04:32 PM
Aaron Cox someone find me those tranny flanges..... Mar 18 2007, 08:42 PM
John A no machining/no spacer solution would be:
1. 76... Mar 18 2007, 10:00 PM
amallagh John/Clay,
very informative post. Can you confirm... Nov 29 2007, 05:24 PM
Krieger914 The 944 axles are too long by about 3/4". Th... Nov 29 2007, 07:08 PM
Elliot Cannon Aaron, are we EVER going to see this car on the ro... Nov 29 2007, 07:11 PM
shoguneagle Excellent articles and could not be more timely. ... Nov 29 2007, 11:00 PM
amallagh John/Clay,
very informative post. Can you confirm... Nov 30 2007, 02:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 09:35 AM |
