ok, so there are two ways to do this im told, you can make a spacer to fill the area on the stub where the dust seal on a 944 used to live, or you can lathe that off, and let the stub sit deeper into the hub-
so here are pics with dimensions......
ill have to go back and write in the dimensions.... cant read the calipers on a few. (shoulda got the digital ones LOL)
the materials required.
Bearing, early 911 hub, 951 stub, calipers.
Bearing width.
diameter of "dust seal area" and diameter of bearing area on hub.
width of dust seal area
width of bearing area on hub
combined....
bearing diameter if you need it.
