> What to do to a 2056 with 2.0 DJet, Help get this motor worked out.
Teknon
post Mar 18 2007, 07:28 PM
The more I learn the dumber i think I am
Ok Motorheads,
Senerio:
New 2056, Slightly more aggressive than stock Isky VP-228 cam, ported 5pt heads with '74 2.0 D-Jetronics. Crane xr700 009 dizzy. Burch exhaust through SSI HX'ers
Question:
What would be some tricks and tips to make this engine more efficient. (IMG:style_emoticons/default/cool_shades.gif)
I thought of having the MPS adjusted for a 2056, read that somewhere. Would like to put an oil cooler in most likely.
What else would be things to concider. The engine is in boxes ready to assemble.
Please chime in
Joe D
Twystd1
post Mar 18 2007, 07:54 PM
You don't want to know... really.....
Lets start here.
Go with a Jake cam. PERIOD.
Reason: You will absolutely know you have a cam AND A MATCHING SET OF LIFTERS THAT WON'T GO FLAT. This is also a proven cam/lifter combo for the factory FI.
Balance the entire reciprocating assembly.
Get your heads checked and machined by a Type IV pro.
Get your block, cylinders, pistons, pins, rings (end gap), machined and checked out by a Type IV pro.
Use Jakes double thrust cam bearing.
You probably wont need and oil cooler. But it never hurts to add one.
I could go on forever.....
OR: Buy a Jake kit and be done with it.
Whats your budget????
Clayton
Teknon   What to do to a 2056 with 2.0 DJet   Mar 18 2007, 07:28 PM
Twystd1   Lets start here. Go with a Jake cam. PERIOD. Rea...   Mar 18 2007, 07:54 PM
Teknon   Budget? That's funny. I have a 2563 78.4mm CC ...   Mar 18 2007, 08:34 PM
Twystd1   I had no idea you knew about engines... YEA......   Mar 18 2007, 08:49 PM
Bleyseng   Get the 9550 cam/lifter set from Jake and then you...   Mar 18 2007, 08:41 PM
Teknon   Dunno how the Djet works with a 009 dizzy sinc...   Mar 18 2007, 08:43 PM
Teknon   Well djet is not really adventageous to use for u...   Mar 18 2007, 09:01 PM
914Sixer   Factory D-Jet dizzy for 2.0 ends in 009 to add to...   Mar 18 2007, 09:05 PM
Gint   Hey Joe! So is that my distributor? ;)   Mar 18 2007, 09:28 PM
Teknon   Hey Joe! So is that my distributor? ;) Ha...   Mar 18 2007, 10:17 PM
Gint   [quote name='Gint' post='876500' date='Mar 18 200...   Mar 18 2007, 10:55 PM
Teknon   [quote name='Gint' post='876500' date='Mar 18 20...   Mar 18 2007, 11:07 PM
jk76.914   I'm running an Isky 229 with D-Jet. Though th...   Mar 18 2007, 10:04 PM
Teknon   I'm running an Isky 229 with D-Jet. Though t...   Mar 18 2007, 10:43 PM
jk76.914   I'm running an Isky 229 with D-Jet. Though ...   Mar 18 2007, 11:17 PM
Teknon   Sure, but it'll be a two-way exchange. I...   Mar 18 2007, 11:21 PM
Bleyseng   I'm running an Isky 229 with D-Jet. Though t...   Mar 19 2007, 01:18 AM
Teknon   I'm running an Isky 229 with D-Jet. Though ...   Mar 19 2007, 10:59 AM
Demick   Trouble is, I'm convincing myself that the pr...   Mar 19 2007, 11:11 AM
pbanders   Trouble is, I'm convincing myself that the p...   Mar 19 2007, 03:55 PM
Krieger914   Bump the fuel pressure up. My 2270 with djet and ...   Mar 18 2007, 10:18 PM
Krieger914   Oh, check the throttle position sensor for your mi...   Mar 18 2007, 10:21 PM
malaga_red75   Trying to learn about engines, as I might be doing...   Mar 18 2007, 10:44 PM
Teknon   Trying to learn about engines, as I might be doin...   Mar 18 2007, 11:11 PM
TROJANMAN   Hey Joe :wavey: have you been hibernating? :gint2:   Mar 18 2007, 11:13 PM
Teknon   Hey Joe :wavey: have you been hibernating? :gint2...   Mar 18 2007, 11:16 PM
Phoenix914   :popcorn: I have a 2056 with D-Jet. I know noth...   Mar 19 2007, 11:54 AM
pbanders   Hey, Demick, your vacuum chart in the postings you...   Mar 19 2007, 03:56 PM
Dan (Almaden Valley)   Demick did you do all your adjustments with the MP...   Mar 19 2007, 04:03 PM
Demick   Demick did you do all your adjustments with the M...   Mar 19 2007, 05:23 PM
pbanders   Demick, I read those postings of your tuning effor...   Mar 19 2007, 04:16 PM
Demick   Brad I'm sure you are correct in your assessm...   Mar 19 2007, 05:14 PM
pbanders   Brad I'm sure you are correct in your assess...   Mar 20 2007, 02:48 PM
- Lo-Fi Version Time is now: 1st August 2025 - 05:08 AM
