| Aaron Cox |
Mar 16 2007, 08:23 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
ok, so there are two ways to do this im told, you can make a spacer to fill the area on the stub where the dust seal on a 944 used to live, or you can lathe that off, and let the stub sit deeper into the hub-
so here are pics with dimensions...... ill have to go back and write in the dimensions.... cant read the calipers on a few. (shoulda got the digital ones LOL) the materials required. Bearing, early 911 hub, 951 stub, calipers. ![]() Bearing width. ![]() diameter of "dust seal area" and diameter of bearing area on hub. ![]() width of dust seal area ![]() width of bearing area on hub ![]() combined.... ![]() bearing diameter if you need it. ![]() |
| John |
Mar 18 2007, 10:00 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
A no machining/no spacer solution would be:
1. 76 911 (915 trans) 6 bolt, coarse spline drive flanges. 2. Complete 944 axle assembly with both CV joints and shaft. (Performance Products 909264) 3. 911 stub axle 6-bolt (1975-1984). 4. 69-73 911 hub. (1974-1989 hubs require 5mm spacers but are for hub centric wheels) just my $0.02 |
Aaron Cox 944 stubs on 911 hubs, the bearing spacer info you need Mar 16 2007, 08:23 PM
John I prefer the later hubs, but then you would probab... Mar 16 2007, 09:18 PM
Luke M Hey, Aaron
Is that the setup that you have on your... Mar 17 2007, 03:32 PM
ClayPerrine
Hey, Aaron
Is that the setup that you have on you... Mar 17 2007, 03:40 PM
Aaron Cox
Hey, Aaron
Is that the setup that you have on yo... Mar 17 2007, 08:09 PM
ClayPerrine
[quote name='ClayPerrine' post='876049' date='Mar... Mar 18 2007, 01:19 AM
LarryR
Hey, Aaron
Is that the setup that you have on you... Mar 17 2007, 10:35 PM
Luke M Clay,
Which setup do you have on your six?
I'm... Mar 17 2007, 05:30 PM
ClayPerrine
Clay,
I... Mar 18 2007, 01:21 AM
John Those 944 axles that bolt up to the coarse spline ... Mar 18 2007, 02:07 AM
Luke M Clay,
Could you break down the parts/years that yo... Mar 18 2007, 08:10 AM
ClayPerrine
Clay,
Could you break down the parts/years that y... Mar 18 2007, 09:02 AM
Luke M Thanks, for the info. Clay.
Looks like that may be... Mar 18 2007, 04:32 PM
Aaron Cox someone find me those tranny flanges..... Mar 18 2007, 08:42 PM
amallagh John/Clay,
very informative post. Can you confirm... Nov 29 2007, 05:24 PM
Krieger914 The 944 axles are too long by about 3/4". Th... Nov 29 2007, 07:08 PM
Elliot Cannon Aaron, are we EVER going to see this car on the ro... Nov 29 2007, 07:11 PM
shoguneagle Excellent articles and could not be more timely. ... Nov 29 2007, 11:00 PM
amallagh John/Clay,
very informative post. Can you confirm... Nov 30 2007, 02:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 09:35 AM |
