> V8 conv engine question., Sat for a long time, should I start?
LowGT
post Mar 19 2007, 10:48 PM
1.8 and Proud!
I bought a V8 conversion project back around Christmas. It's pretty much done and saw some minimal road time, then it sat for 6 years or so.
I put some oil in the spark plug holes several times in the last few months. I just tried to turn the motor but the starter wouldn't do it. I couldn't get a socket or anything on the crank pulley because its very close to the firewall, so I locked one wheel and turned the other. With some moderate coaxing in the beginning, it turns pretty good now. The starter turns it weakly with the plugs out, but it is a stock 914 unit.
Its a Rod Simpson conversion that I plan on updating with a few Renegade parts. I want to put the mount bar and trans mounts to move the motor back, as well as the Renegade cooling system. I'd like to hear to engine sputter before I do all that, but do you think the motor is okay since it was slightly stuck?
Dan
Crazyhippy
post Mar 19 2007, 10:53 PM
Insert witty comment here...
Try it, worst case you have to re-build... you would be re-building anyways... If you lunch a bore or rings or whatnot, you just have a lil more work on the re-build, but it's a SBC, Parts are available everywhere.
BJH
- Lo-Fi Version Time is now: 6th March 2026 - 11:11 PM
