| Aaron Cox |
Mar 18 2007, 10:56 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
motor ate a head gasket. pulled it apart before it could flame cut a cylinder or head.
so its apart. 71 x 94, with LARGE cam. has mahle euro '8:1 pistons" in it. deck was setup at .031 but was running a head gasket. heads have never been decked/surfaced. pulled em and cleaned em, 2 chambers have a sparkplug crack starting - so they need to be welded. while its apart, i plan to re-ring it, hone the barrels, get the heads done, and??? questions - what rings do you recommend for mahle pistons? certain rings justify certain hone finishes right? heads need welding. valves are sealing great to the seats. guides are good. (motor has 35 k on it since full rebuild.) when the head gets welded, will this require new seats/guides and a resurface? what is the proper welding setup- my machinist may want to weld em cold, but i was told to pre heat em first - your thoughts? when reassembling - how tight can i go on deckheight? the euro pistons have a .034" dish to em. should i trim the pistons .034 to make them flat, and trim the cylinders accordingly also? trying to get as much CR with these 94mm pistons as i can, and running 91 gas. last question- cam. how does the cam affect deck height? how tight can i go? going to CC my heads tomorrow - before machining.... what is the range for a stock 2L head? 55-65cc's? *on reassembly - head gasket will be omitted, and cylinders will be lapped into the head. valves will also be lapped into their seats again. |
| brer |
Mar 20 2007, 01:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
I'll weld them for you Homeboy.
Aaron Cox Doing a top end/upgrade. couple questions Mar 18 2007, 10:56 PM
Dave_Darling Welding the heads is not a simple process; you do ... Mar 18 2007, 11:27 PM
Aaron Cox
Welding the heads is not a simple process; you do... Mar 18 2007, 11:37 PM
Dan (Almaden Valley) If you weld you will need to redo the whole enchil... Mar 18 2007, 11:45 PM
Brando
questions - what rings do you recommend for mahle... Mar 18 2007, 11:50 PM
Aaron Cox good info brandon, and as i was guessing..
dan - ... Mar 18 2007, 11:55 PM
Brando If you got it apart that far bro, find a 78.4mm cr... Mar 19 2007, 12:01 AM
McMark If you have a dish in your pistons your can go low... Mar 19 2007, 01:09 AM
Twystd1 If you mill the top of the pistons, and cut the ba... Mar 19 2007, 01:43 AM
Bleyseng yep, buy the exhaust and rocker studs from Jake as... Mar 19 2007, 08:43 AM
Aaron Cox but any cam should clear a .030 deck right? Mar 19 2007, 09:25 AM
Aaron Cox dropped the heads off at the machinist to get...
-... Mar 19 2007, 05:07 PM
craig downs Hey Clayton from the top of the piston down to the... Mar 19 2007, 08:48 PM
Aaron Cox hoping for around a 54cc head..... Mar 19 2007, 08:55 PM
Matt Romanowski As for clearance from valves to pistons, do what e... Mar 19 2007, 09:11 PM
Aaron Cox
As for clearance from valves to pistons, do what ... Mar 19 2007, 09:20 PM
Twystd1 I am just wondering if .269 is safe for the top ri... Mar 19 2007, 09:24 PM
Aaron Cox any comments on 'grant' rings? Mar 19 2007, 09:26 PM
craig downs His Mahles don't have gas ports Mar 19 2007, 09:38 PM
Twystd1 Then he might not want to cut the pistons if he is... Mar 19 2007, 10:27 PM
Twystd1 Jake says the original rings for Mahle's were ... Mar 19 2007, 10:50 PM
Crazyhippy Ahem...
http://www.carma.com.sg/img/buyersguide/l... Mar 19 2007, 10:59 PM
McMark I have a vague recollection that Grant rings are C... Mar 20 2007, 03:07 PM
Twystd1 I agree with McMark. Same for Total Seal.
Much li... Mar 20 2007, 04:08 PM
Aaron Cox or you could man up and talk to john :) he misses ... Mar 20 2007, 06:58 PM
Matt Romanowski You need to measure the gap in the ring groove wit... Mar 20 2007, 07:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th June 2026 - 01:38 PM |
