> blowing out fuses..Can I get a circut breaker?
buck toenges
post Mar 20 2007, 11:44 AM
Does anybody make a ciruit breaker for the fuse panel that replaces a fuse so to pin down a wiring problem? The circuit breaker would replace the fuse and fit in the fuse panel so when you try and track down the wiring issue the circuit breaker would click off and could be reset. This way you could save a ton of money buying fuses.
elwood-914
post Mar 20 2007, 01:49 PM
elwood-914
I'd fix the problem first before I invest in circuit breakers. They are not going to be the answer to your problem. Fuses are fine.
When you reset breakers repeatedly, they heat up and get weak.
Try a meter.
buck toenges   blowing out fuses..Can I get a circut breaker?   Mar 20 2007, 11:44 AM
jasons   Never heard of anything like that. I'm afraid...   Mar 20 2007, 12:56 PM
bd1308   I think the Apollo 13 had circuit breakers. I als...   Mar 20 2007, 01:00 PM
bperry   Does anybody make a ciruit breaker for the fuse p...   Mar 20 2007, 01:16 PM
Cap'n Krusty   Any auto parts store. I've bought them at Car...   Mar 20 2007, 01:41 PM
elwood-914   I'd fix the problem first before I invest in c...   Mar 20 2007, 01:49 PM
buck toenges   I might try the aligator clips. You're right ...   Mar 20 2007, 03:50 PM
rhodyguy   is it the same couple of fuses all of the time? k   Mar 20 2007, 03:54 PM
bondo   Replace the fuse with a 12v light bulb. A short or...   Mar 20 2007, 04:30 PM
McMark   You can also share the problem with us and we can ...   Mar 20 2007, 04:32 PM
buck toenges   How do yo hook up the light bulb? I'd share t...   Mar 20 2007, 07:01 PM
StratPlayer   Argh I feel your frustration, I'm going throug...   Mar 20 2007, 07:34 PM
rhodyguy   what does #9 control? can't remember off the t...   Mar 21 2007, 11:15 AM
StratPlayer   what does #9 control? can't remember off the ...   Mar 21 2007, 11:29 AM
pbanders   Hi Kevin, nope haven't had the bumper off. L...   Mar 21 2007, 03:27 PM
rhodyguy   4 bolts and the little nut in the center of the pa...   Mar 21 2007, 11:54 AM
pbanders   If you want to find the cause of the problem, do t...   Mar 21 2007, 02:56 PM
pbanders   FWIW, what I wrote is specific to the '73 wiri...   Mar 21 2007, 04:19 PM
StratPlayer   Thanks Brad for a great reply, my car is a 76 so w...   Mar 21 2007, 04:35 PM
pbanders   Thanks Brad for a great reply, my car is a 76 so ...   Mar 21 2007, 05:27 PM
Dave_Darling   The 76 wiring diagram is identical to the 75. Whi...   Mar 21 2007, 10:02 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:15 AM
