KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Brad,
Front struts must be stock. Bp class. Cannot get too low or will not have any shock travel. How do you determine the ride height?? Position of A-arms?? If so, parallel to ground or at what angle? Shock travel to stop dimension?? If fender lip - want size tires?? After the front is set do you adjust the rear for level or some amount of forward rake?? Ken |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Oh yeah.. I forgot.
20 3/4 on both rears thru the centerline of the wheel from ground to the stock fender lip. 21 7/8 on the right front thru the centerline of the wheel from ground to the stock fender lip 21 3/4 on the left front thru the centerline of the wheel from ground to the stock fender lip This will put the cornerweights very very close for you. I weigh 200lbs.. so it will be a tad different for you. All this is with 3/4 take of gas and the driver in the seat with 205/50/15 Hoosier road race tires. B |
Lo-Fi Version | Time is now: 6th July 2025 - 11:07 AM |
