> 73 2.0 djet idle problem
jasons
post Mar 19 2007, 09:22 AM
Jackstand Extraordinaire
Car is a 73 2.0, new TPS, new FI Points, new TS1, existing TS2 (its the 017), all intake runners, hoses, gaskets, and PCV are new, injectors were cleaned and serviced by witchhunter. Also all parts are correct for the 73 2.0. I put a 270ohm resistor in too. Car seems to run lean at idle (I have an air fuel meter).
I had the wrong TS2, because I replaced it with what I thought was the correct replacement. Upon further review, I put the used 017 piece back in.
The car had been sitting when I bought it, so I dropped the motor to take care of a few problems, and I refurbed the FI while I was at it.
Car seems to have good power and pull hard, but it doesn't seem to idle quite right. It oscillates between, 1000 and less than 500, while the air meter reads lean. Air bleed and the knob both effect idle, but I can't get it to stabilize or richen up on the meter.
Also, I have a euro-race header and MSD. Should I play with the resistor or the FPR to richen the car for these parts?
Gint
post Mar 21 2007, 08:47 AM
Mike Ginter
The Pertronix should have cured *minor* distibutor shaft wobble. So unless it's really bad...
jasons   73 2.0 djet idle problem   Mar 19 2007, 09:22 AM
sean_v8_914   does yoour ECU have the mixture potentiometer?   Mar 19 2007, 09:37 AM
jasons   does yoour ECU have the mixture potentiometer? ...   Mar 19 2007, 09:44 AM
Demick   First thing - unless your O2 sensor is a wideband ...   Mar 19 2007, 11:35 AM
jasons   First thing - unless your O2 sensor is a wideband...   Mar 19 2007, 12:04 PM
Demick   Relocated fuel pump shouldn't cause any issues...   Mar 19 2007, 12:07 PM
2-OH!   Run the engine to operating temp...At this point, ...   Mar 19 2007, 02:12 PM
jasons   I did time it, but that was when I was using the...   Mar 19 2007, 02:18 PM
bob174   You do have a good MPS right? Have you pulled a v...   Mar 19 2007, 08:01 PM
jasons   You do have a good MPS right? Have you pulled a ...   Mar 19 2007, 08:56 PM
Bleyseng   You do have a good MPS right? Have you pulled a ...   Mar 20 2007, 08:37 AM
jasons   When I had the motor out I checked all the parts a...   Mar 20 2007, 09:13 AM
Bleyseng   When I had the motor out I checked all the parts ...   Mar 20 2007, 04:38 PM
jasons   When I had the motor out I checked all the parts...   Mar 20 2007, 04:51 PM
Dave_Darling   Low fuel pressure will cause a lean condition. Tr...   Mar 20 2007, 09:33 AM
jasons   OK so bumping the Fuel Pressure didn't make a ...   Mar 20 2007, 03:56 PM
pbanders   We've been through this drill about a million ...   Mar 20 2007, 05:41 PM
jasons   Brad, I can't tell you how much time I have sp...   Mar 20 2007, 06:16 PM
Bleyseng   Have you checked for vacuum leaks at the usual spo...   Mar 20 2007, 09:55 PM
jasons   Have you checked for vacuum leaks at the usual sp...   Mar 20 2007, 10:34 PM
Bleyseng   How much is the timing mark "walking"? m...   Mar 20 2007, 10:40 PM
jasons   How much is the timing mark "walking"? ...   Mar 20 2007, 10:44 PM
Bleyseng   There is some up/down play but there shouldn't...   Mar 21 2007, 12:02 AM
jasons   There is some up/down play but there shouldn...   Mar 21 2007, 08:37 AM
Gint   The Pertronix should have cured *minor* distibutor...   Mar 21 2007, 08:47 AM
jasons   OK so, I installed the new vacuum pod and un-delet...   Mar 21 2007, 11:11 PM
- Lo-Fi Version Time is now: 14th March 2026 - 04:44 PM
