full flow question, anyone make a filter blockoff plate with fitting? |
Aaron Cox |
Mar 24 2007, 07:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hey all!
fullflowing question. i have a 38mm pump (yes 38mm) with gears supported by both sides, and a regular cover plate on it. (cant find manufacturer - got it from steve stromberg :cringe: ) i do not know the pump manufacturer, so thus i cannot get a full flow cover for it. i like the larger pump because i have a front cooler and -10 lines. i want to full flow my motor.... so the passage from the pump that goes diagonally upwards toward the filter and 1st galley plug.... i could tap that galley with an elbow to EXIT the case and go to a remote filter... and come back into the case through the standard galley plug next to it.... but my question- to make it more simple.... and not require two elbows out of the case... does anyone make a filter blockoff plate with an AN fitting in the bottom passage? thus i would not have to use a second elbow- |
41ghost |
Mar 24 2007, 07:50 PM
Member Group: Members Posts: 235 Joined: 13-July 04 From: noblesville,in. Member No.: 2,345 |
from what i understand , with a tpye 4 you do not want to do that. you need to get a oil punp plate with a out let for the oil to be pumped out there. themn there it a plug just up from there and this will be for your return. if you get a full flow system with filter relocator and oil cooler with fan they usually come with every thing you need, plus a galley plug kit from jake, and you should be set. it looks like this.
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 02:33 AM |
