full flow question, anyone make a filter blockoff plate with fitting? |
Aaron Cox |
Mar 24 2007, 07:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hey all!
fullflowing question. i have a 38mm pump (yes 38mm) with gears supported by both sides, and a regular cover plate on it. (cant find manufacturer - got it from steve stromberg :cringe: ) i do not know the pump manufacturer, so thus i cannot get a full flow cover for it. i like the larger pump because i have a front cooler and -10 lines. i want to full flow my motor.... so the passage from the pump that goes diagonally upwards toward the filter and 1st galley plug.... i could tap that galley with an elbow to EXIT the case and go to a remote filter... and come back into the case through the standard galley plug next to it.... but my question- to make it more simple.... and not require two elbows out of the case... does anyone make a filter blockoff plate with an AN fitting in the bottom passage? thus i would not have to use a second elbow- |
41ghost |
Mar 24 2007, 07:56 PM
Member Group: Members Posts: 235 Joined: 13-July 04 From: noblesville,in. Member No.: 2,345 |
i asked jake the same guestion and he would be better at answering that, i cannot explain it like he does. but you will get better flow this way.
Lo-Fi Version | Time is now: 7th June 2024 - 02:46 PM |
