full flow question, anyone make a filter blockoff plate with fitting? |
Aaron Cox |
Mar 24 2007, 07:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hey all!
fullflowing question. i have a 38mm pump (yes 38mm) with gears supported by both sides, and a regular cover plate on it. (cant find manufacturer - got it from steve stromberg :cringe: ) i do not know the pump manufacturer, so thus i cannot get a full flow cover for it. i like the larger pump because i have a front cooler and -10 lines. i want to full flow my motor.... so the passage from the pump that goes diagonally upwards toward the filter and 1st galley plug.... i could tap that galley with an elbow to EXIT the case and go to a remote filter... and come back into the case through the standard galley plug next to it.... but my question- to make it more simple.... and not require two elbows out of the case... does anyone make a filter blockoff plate with an AN fitting in the bottom passage? thus i would not have to use a second elbow- |
41ghost |
Mar 24 2007, 10:20 PM
Member Group: Members Posts: 235 Joined: 13-July 04 From: noblesville,in. Member No.: 2,345 |
if you are racing you may want to look at it differently than the way it is set up on my car. i have a old case that rick cleaned up like new i'll take a look at it and maybe do some drilling and repluging, just to see what i can do with it. it would be nice to use the original oil filler holes but you will still have one 90 within the case, or one 90 comming out of the front of the case. or use two 45's comming out . that would even be better, to lessen the turn. when i was building this i was toying with comming strait out and going strait through the fan housing with the hoses ' i'm sure that would work too. you would have to drill and tap to come strait out the pump cover and plug the intended exit hole but i think that would work great too. just silicone around the holes where the hose passes through the housing.
Lo-Fi Version | Time is now: 8th June 2024 - 04:39 AM |
