full flow question, anyone make a filter blockoff plate with fitting? |
Aaron Cox |
Mar 24 2007, 07:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hey all!
fullflowing question. i have a 38mm pump (yes 38mm) with gears supported by both sides, and a regular cover plate on it. (cant find manufacturer - got it from steve stromberg :cringe: ) i do not know the pump manufacturer, so thus i cannot get a full flow cover for it. i like the larger pump because i have a front cooler and -10 lines. i want to full flow my motor.... so the passage from the pump that goes diagonally upwards toward the filter and 1st galley plug.... i could tap that galley with an elbow to EXIT the case and go to a remote filter... and come back into the case through the standard galley plug next to it.... but my question- to make it more simple.... and not require two elbows out of the case... does anyone make a filter blockoff plate with an AN fitting in the bottom passage? thus i would not have to use a second elbow- |
Aaron Cox |
Mar 24 2007, 10:21 PM
so now you understand the approach.... probably not enough room for a sweeping AN 90 behind the shroud....
case is already tapped with 3/8 npt. so the original question. IS THERE a block off plate for the filter console with a fitting installed on the lower passage? |
jwalters |
Mar 24 2007, 10:27 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
so now you understand the approach.... probably not enough room for a sweeping AN 90 behind the shroud.... case is already tapped with 3/8 npt. so the original question. IS THERE a block off plate for the filter console with a fitting installed on the lower passage? No, there is plenty of room!! I measured about 2 1/2 inches behind mine and nandos.... Just keep the sweep small - avoid a 'hard' 90 is all - you can do it! No, no block off plates - drill, thread and pipe attachment fit - while you are at it, tap and plug the other hole. Just use heavy grease on the tap, it will catch the shavings .. |
Aaron Cox |
Mar 24 2007, 10:29 PM
so now you understand the approach.... probably not enough room for a sweeping AN 90 behind the shroud.... case is already tapped with 3/8 npt. so the original question. IS THERE a block off plate for the filter console with a fitting installed on the lower passage? No, there is plenty of room!! I measured about 2 1/2 inches behind mine and nandos.... Just keep the sweep small - avoid a 'hard' 90 is all - you can do it! No, no block off plates - drill, thread and pipe attachment fit - while you are at it, tap and plug the other hole. Just use heavy grease on the tap, it will catch the shavings .. thats an interesting idea. case isnt being taken apart...... i should (have to!) beable to get all the shavings out. with the oil pump to filter passage, you have access to both ends to clean it out (and a galley plug) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:46 PM |
