Temp Gauge, How do I stop the wiggle |
BiG bOgGs |
Mar 24 2007, 03:19 PM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
Since my ass reamin....I mean since I got my 914 back from the mechanics, my temp gauge wiggles then pauses, then wiggles, over and over again. Where should I look to track down the problem? (IMG:style_emoticons/default/confused24.gif)
Jim |
Spoke |
Mar 24 2007, 11:50 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Where did the mechanics work? Sounds like a wire is loose. The sender is under the engine in the taco plate. When you say wiggles, I assume that the gauge goes from engine temp to cold and back. If the sender was open circuited (loose wire), the gauge will read cold.
Spoke |
John |
Mar 25 2007, 12:11 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Where did the mechanics work? Sounds like a wire is loose. The sender is under the engine in the taco plate. When you say wiggles, I assume that the gauge goes from engine temp to cold and back. If the sender was open circuited (loose wire), the gauge will read cold. Spoke I agree. Look at the areas where they may have disturbed a wire. Check the temp wire as it passes through the engine sheet metal under where the battery lives. There is a single wire that connects to the harness there. If the wire leading down through the engine sheet metal has any cuts or abrasions, it may momentarily short to ground causing all kinds of gauge readings. Other than that, as the others have said, look for loose wires:The sender wire, the ground wire, and the sender wire at the taco plate. Good luck. |
Lo-Fi Version | Time is now: 8th June 2024 - 08:09 AM |
