full flow question, anyone make a filter blockoff plate with fitting? |
Aaron Cox |
Mar 24 2007, 07:39 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hey all!
fullflowing question. i have a 38mm pump (yes 38mm) with gears supported by both sides, and a regular cover plate on it. (cant find manufacturer - got it from steve stromberg :cringe: ) i do not know the pump manufacturer, so thus i cannot get a full flow cover for it. i like the larger pump because i have a front cooler and -10 lines. i want to full flow my motor.... so the passage from the pump that goes diagonally upwards toward the filter and 1st galley plug.... i could tap that galley with an elbow to EXIT the case and go to a remote filter... and come back into the case through the standard galley plug next to it.... but my question- to make it more simple.... and not require two elbows out of the case... does anyone make a filter blockoff plate with an AN fitting in the bottom passage? thus i would not have to use a second elbow- |
jwalters |
Mar 25 2007, 11:10 AM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Yo Aaron -how big of a drill bit did you have to use to bore out the case??? I am just curious as to just how big that big pump is - - The engine I am building right now is going into my airplane and I was thinking of two possible routes
1. - Use the dry sump pump and go full dry - 2. Keep the sump wet with an inverted pick-up / breather supply. To use #2 I would need a very high capacity pump............. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:28 AM |
