Need info on '76 Air Injection System, I bet the Cap'n knows, anyone else? |
Porsche Rescue |
Mar 26 2007, 06:08 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am going to sell my '76 914. It is a Texas car and never had a catalyst.
It does appear to have once had an air pump but not sure. The not so good pic below shows the large silver collector tube which is capped off. I assume it would not pass CA smog test in this condition. What parts would be required to replace the system and does anyone out there have them? Is the pump driven off the crank? And if so should I find an empty pully down beside the alternator driver? Attached File(s) 6.bmp ( 87.94k ) Number of downloads: 37 |
ejm |
Mar 26 2007, 06:41 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The capped off valve is #14. You'll need everything to the right of it in this pic. If the pulley drive is still there make sure it's not broken. Often the pump seize's and sheers the rubber.
Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 08:23 AM |
