Bus clutch in 914 |
Bus clutch in 914 |
bd1308 |
Mar 27 2007, 06:21 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
How can I make a bus clutch work in my 914....?
I'm due for a clutch swap and have heard that bus clutches work with mods and are available locally, while Porsche things need to be ordered. I figure a flywheel change is in order, as well as different clutch/flywheel...... |
hellsbend |
Mar 28 2007, 12:52 AM
Member Group: Members Posts: 70 Joined: 27-February 06 From: Lakeport, CA Member No.: 5,646 |
the bus pressure plate is taller due to a different shape of the tangs that the TOB rides on. There really isn't room for the bus pressure plate to work right, and I think the bus TOB is smaller in diameter as well-which means the wrong part of the tang is bearing the load. The disk is the same, but the flywheel has a different offset so correct starter ingaugement may be a problem.
Lo-Fi Version | Time is now: 6th June 2024 - 06:23 AM |
