Clutch Issue, Help! |
bd1308 |
Mar 29 2007, 09:54 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
OK, the clutch acts liek its slipping (not engaging fully when pedal released) *ONLY* when driving for longer periods of time.
Is it possible that the clutch is adjusted too far, but not far enough to cause trouble when cold?? also, is it logical that the clutch would ever tighten??? Or maybe the pressure plate is dead? |
bd1308 |
Mar 29 2007, 10:42 PM
See
here's the wierd part--worked fine until now. Could a clutch tighten with use, or does it just get more loose |
So.Cal.914 |
Mar 29 2007, 10:59 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
See here's the wierd part--worked fine until now. Could a clutch tighten with use, or does it just get more loose I don't think I have ever seen one tighten up with use, I have seen the adjustment nut loosen with use (add another nut and tighten together), but tighten? New one on me. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:52 AM |
