MiddleGACruiser |
Hobbits? What Hobbits? ![]() ![]() Group: Members Posts: 115 Joined: 5-September 04 From: Porschenaire, GA Member No.: 2,694 Region Association: None ![]() |
I've just installed a new clutch and the fork has .525 inch free play. I've read it should have about a half inch but not over that and if it does I should shim the ball behind the fork. Is .525 too much and should I shim the ball?
spunone |
Senior Member ![]() ![]() ![]() Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California ![]() |
Just wondering how do you measure the free play?
MiddleGACruiser |
Just wondering how do you measure the free play? I took the measurement with the transmission out of the car. You can do it in the car with the cable disconnected. Push the fork forward as far as it goes. I use a plunge micrometer, place it on the fork where the cable connects, set the plunger about 1 inch out then zero the mic. I push the fork to the rear and measure the distance it travels. |
Lo-Fi Version | Time is now: 13th June 2024 - 08:41 PM |
