Clutch Help Needed...what's wrong?, lots of pics..."Where' Waldo?" |
computers4kids |
Mar 30 2007, 04:10 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Brand new 215 SACHS clutch, pressure plate, throwout, and re-surfaced flywheel. With the trans bolted, and no clutch cable connected, the clutch should be engaged--but it is not. You can also move the clutch arm without too much effort.
Took everything apart and all looks good??? Could the throwout bearing be depressing the plate from some reason when I bolt it all up....which would explain why the clutch is not by default engaged and the clutch arm is not to hard to move? I'm thinking the plate fingers are partially depressed making them easier to move further. There is one washer under the clutch pivot arm from when I did a new clutch when I had the 1.8 motor. Looking for ideas...I'm baffled... Attached image(s) |
jr91472 |
Mar 30 2007, 05:48 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Now this may or may not apply to your situation. But when I installed my lighten flywheel, I had to add a washer underneath the pivot ball that the clutch forks sits on. This was because the flywheel had some of the surface, where the p-plate mounts, removed.
The extra washer restored the proper spacing. Like I said, the may or may not apply to you. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 04:23 AM |
