QUOTE(So.Cal.914 @ Mar 30 2007, 05:47 PM)
QUOTE(computers4kids @ Mar 30 2007, 04:10 PM)
(By what process did you determine the clutch disk was not engaged? ) Alright...I'm about ready to possibly show my ignorance....
With both rear wheels off the ground and everything back together I was going to adjust the valves and tried rotating one of the wheels to turnover the engine...this is when I realized the wheels and trasmission turned just fine, but the engine would not. I believed since the wheels and tranny turned and I should be able to see through the view hole of the bottom of the trans that the engine would be turning...which it was not.
So I completly took the clutch cable off...still the same.
Put car in gear...started engine...idle...one wheel just slowly turned and I could stop it easily with my foot.
If I am reading this right and the transaxle you have does not have a LSD
then it is acting like it should. Unless you chalk up one wheel its just going to spin.
When you turn it one wheel goes one way and one goes the other? Let us know.
After measuring all the cuts on the flywheel and finding them within tolerance and having a local shop take a peek at my pressure plate and disk, I decided to put it all back in.
Well, I put the tranny back in...from what I read I had too much travel of the clutch arm so I put another washer under the pivot arm...even though it shouldn't have anything to do with my problem mentioned above--Although, a good idea for pedal adjustment.
Fired it and up and low and behold the clutch worked beautifully. Drove around the block and it shifted and ran not to bad considering my MPS won't hold a vaccumm--a good one has been ordered..ouch!
The engine has new rings, bearings...basic rebuild...so I guess I should go through the break-in routine. The motor seems louder than my 1.8...must be the stainless exchangers in lieu of the stock pipes. Or maybe I now have an extra squirrel or two under the hood than before.
So the question is...why did it work this time? Did the washer under the pivot arm do the trick...no that would only help with dis-engaging the clutch.
Either I just did numerous hours of pulling the trans, etc etc for nothing and got lucky, or perhaps the 914 gremlins felt sorry for me...
Can't decide whether to laugh or cry....ah hell,
As soon as I know it's ship worthy...it's time for me
and the mrs.
to go for a drive!
