relocating fuel pump to front on 73, can i grab the fuel pump hot wire up front? |
orange914 |
Apr 3 2007, 10:43 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
relocating fuel pump to front on my 73, (IMG:style_emoticons/default/headbang.gif) can i grab the fuel pump hot wire from harness in front area? if so what color, where and would it be easier than runnig hot from rear location (up the tunnel, as its open anyway 'cause im doing fuel lines).
ClayPerrine |
Apr 4 2007, 08:42 AM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I pull the hot lead for the pump back to the point where it can be turned up the harness heading forward. Then I extend it, following the harness until I get under the tank. I add a ground wire that is hooked to the ground connection next to the fuse box. Works just like the factory intended. And that is how the factory did it on the 75/76 cars. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:48 PM |
