relocating fuel pump to front on 73, can i grab the fuel pump hot wire up front? |
orange914 |
Apr 3 2007, 10:43 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
relocating fuel pump to front on my 73, (IMG:style_emoticons/default/headbang.gif) can i grab the fuel pump hot wire from harness in front area? if so what color, where and would it be easier than runnig hot from rear location (up the tunnel, as its open anyway 'cause im doing fuel lines).
toon1 |
Apr 4 2007, 12:34 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
BTW.... if you relocate the pump you also need to relocate the filter. when I did mine I cut the filter holder off in the engine bay and re welded in the fuel tank bay, under the fuel tank .
worked great, I can get the filter out through the access hole under the car to change it. (IMG:style_emoticons/default/biggrin.gif) Keith |
orange914 |
Apr 4 2007, 04:06 PM
BTW.... if you relocate the pump you also need to relocate the filter. when I did mine I cut the filter holder off in the engine bay and re welded in the fuel tank bay, under the fuel tank . worked great, I can get the filter out through the access hole under the car to change it. (IMG:style_emoticons/default/biggrin.gif) Keith i picked up 95 f150 fuel injection filter, has nice ends to clamp and should trap alot with lots of capacity too. (IMG:style_emoticons/default/driving.gif) |
SLITS |
Apr 4 2007, 04:11 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
BTW.... if you relocate the pump you also need to relocate the filter. when I did mine I cut the filter holder off in the engine bay and re welded in the fuel tank bay, under the fuel tank . worked great, I can get the filter out through the access hole under the car to change it. (IMG:style_emoticons/default/biggrin.gif) Keith i picked up 95 f150 fuel injection filter, has nice ends to clamp and should trap alot with lots of capacity too. (IMG:style_emoticons/default/driving.gif) Oh shit .... it'll never run now. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:17 PM |
