relocating fuel pump to front on 73, can i grab the fuel pump hot wire up front? |
orange914 |
Apr 3 2007, 10:43 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
relocating fuel pump to front on my 73, (IMG:style_emoticons/default/headbang.gif) can i grab the fuel pump hot wire from harness in front area? if so what color, where and would it be easier than runnig hot from rear location (up the tunnel, as its open anyway 'cause im doing fuel lines).
IronHillRestorations |
Apr 4 2007, 07:28 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You could tap onto any fuse above #6, and it would be switched. I would confirm this by hooking up a test light as well as checking the amperage of the fuse. Sorry it's early and I don't have my notes here. I have done this myself without any problems. I have also incorporated a switch and on one installation an inertia cutoff switch.
Air_Cooled_Nut |
Apr 5 2007, 01:33 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
You could tap onto any fuse above #6, and it would be switched. I would confirm this by hooking up a test light as well as checking the amperage of the fuse. Sorry it's early and I don't have my notes here. I have done this myself without any problems. I have also incorporated a switch and on one installation an inertia cutoff switch. Not meaning to pick on you but since you brought it up: It's a good thing you put in the inertia switch because this is a terrible solution. Most people would simply skip the inertia switch. When the FI brain senses the motor not running it turns off the fuel pump...like in an accident. Don't want the pump filling the scene with gas and a manual switch is useless when you're unconscience (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:43 PM |
