| Brando |
Apr 5 2007, 03:41 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Well, looks like I might get to do some racing this year afterall -- just not in the teener.
GF's dad wants to run his bug in the stock 1600 class of offroad racing, wants a wrench hand/driver and I'll probably be it! Tonight I have to go over the rulebook. Soon we have to take the engine that's in it out, split the case and do a cam swap (per rulebook spec). We also have to trim down from the dual kadrons that are on there to a Pict 30 -- byebye torque/hp. Everyone in this class is limited, target HP for your engine should be 85-100 with stock everything. Like any good racing team we'll be looking for loopholes (read: not cheating) and probably blueprint the engine in an attempt to achieve the maximum power we can from the little Type 1. Our goal is 100hp. So far we haven't found any limitation on what kind of gearbox we can use -- so quite possibly we'll go with an early 911 or 912 901 5-speed. This would allow us to gear 1-4 low enough and provide us with a 5th gear for highway cruising to events (we plan to make this street legal as well). We were planning on using a bus box and adapting to the 930 output flanges and complete axles. Since these types of events and racing is new to me, anyone have some suggestions or ideas to help us get in the right direction? thanks! |
| Brando |
Apr 5 2007, 04:33 PM
Clayton,
First off: Man, you're ugly. (IMG:style_emoticons/default/wavey.gif) Second, thank you much for the input. I will call Len. I still have his cards and brochures from that STF dinner last year. I think we could go spraybar on the trans, but implementing a pump would be a bitch. For the engine we're limited to their designated cam and everything stock/original per the OE engine specs. Heads can't have any material cut away (unless welded up and machined to stock clearances), deck height I think can be cheated a bit by not running head gaskets, but valve sizes, ports, crank rods etc all have to be stock. What a challenge... If I could afford Raby's prices shit yeah, but we're gonna be a CSOB team. |
| Aaron Cox |
Apr 5 2007, 04:44 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
Clayton, First off: Man, you're ugly. (IMG:style_emoticons/default/wavey.gif) Second, thank you much for the input. I will call Len. I still have his cards and brochures from that STF dinner last year. I think we could go spraybar on the trans, but implementing a pump would be a bitch. For the engine we're limited to their designated cam and everything stock/original per the OE engine specs. Heads can't have any material cut away (unless welded up and machined to stock clearances), deck height I think can be cheated a bit by not running head gaskets, but valve sizes, ports, crank rods etc all have to be stock. What a challenge... If I could afford Raby's prices shit yeah, but we're gonna be a CSOB team. that was john edwards from costa mesa machine.... (IMG:style_emoticons/default/poke.gif) |
Brando SOT: Buggy Racing Apr 5 2007, 03:41 PM
Twystd1 Can you legally run a spray bar on a trans in your... Apr 5 2007, 03:50 PM
cnavarro I have Nickies too made up for the 1600 class. I h... Apr 5 2007, 05:00 PM
Jake Raby I have a combo that makes 105 HP for that class.. ... Apr 5 2007, 06:15 PM
Our goal is 100hp.
100HP seems a bit high with a... Apr 5 2007, 06:27 PM
Twystd1 Johns pistons ONLY work with his cams. They work l... Apr 5 2007, 06:33 PM
Twystd1 Brando, we need to go to Jakes and download his br... Apr 5 2007, 08:27 PM
alpha434 Hehe.
EDIT: nevermind. Apr 5 2007, 08:51 PM
LvSteveH A lot of good advice. It sounds more like you... Apr 6 2007, 09:57 PM
Brando Thanks for the input guys. I always appreciate hea... Apr 7 2007, 06:47 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:37 PM |
