temporary remote start |
machina |
Apr 9 2007, 11:35 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
i want to be able to crank the motor while i'm near the engine bay. if i run a wire from a push button switch to the single small gauge wire on the starter, will it work? where does the second wire from the switch go? to a ground?
bd1308 |
Apr 9 2007, 11:38 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
if you put 12V on that yellow wire going to the starter it WILL crank
I did this for several months while I diagnosed some wiring issues--found the issue when my clutch, speedo and brake cables got used as the ground for my starter! |
machina |
Apr 9 2007, 11:46 PM
if you put 12V on that yellow wire going to the starter it WILL crank I did this for several months while I diagnosed some wiring issues--found the issue when my clutch, speedo and brake cables got used as the ground for my starter! so what's the easiest way to rig that? also, what happened, was your ground strap from the tranny missing? |
Lo-Fi Version | Time is now: 10th June 2024 - 04:03 PM |
