temporary remote start |
machina |
Apr 9 2007, 11:35 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
i want to be able to crank the motor while i'm near the engine bay. if i run a wire from a push button switch to the single small gauge wire on the starter, will it work? where does the second wire from the switch go? to a ground?
r_towle |
Apr 9 2007, 11:45 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
with carbs.
you need power to the coil. 12 jumper lead power to the fuel pump jumper lead push button from yellow lead on the starter to power on the battery. the button needs to be rated for 50 amps or it will melt. Dont crank to long or the wire will melt. Rich |
machina |
Apr 9 2007, 11:47 PM
with carbs. you need power to the coil. 12 jumper lead power to the fuel pump jumper lead push button from yellow lead on the starter to power on the battery. the button needs to be rated for 50 amps or it will melt. Dont crank to long or the wire will melt. Rich doesn't the big wire from the battery to the starter carry the big amps? |
Lo-Fi Version | Time is now: 10th June 2024 - 10:58 AM |
