temporary remote start |
machina |
Apr 9 2007, 11:35 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
i want to be able to crank the motor while i'm near the engine bay. if i run a wire from a push button switch to the single small gauge wire on the starter, will it work? where does the second wire from the switch go? to a ground?
Dave_Darling |
Apr 10 2007, 12:46 AM
If you don't want the engine to start, you don't have to power up the coil and fuel pump (and EFI if you have that). Just get a switch that hooks up to the fat black wirethat hooks onto the starter solenoid and the flag terminals on the starter solenoid. Rig it so that those get connected together when you press the button.
And yeah, make sure the switch can handle 50 amps or so... --DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:34 AM |
