| Chris Pincetich |
Apr 10 2007, 04:51 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I found myself really hangin on tight to the wheel while AXing last year because my stock 3 pt belts did not match the G-forces as I cranked through turns. Adding harnesses this year is a MUST, for AX and my late 07-2008 DE/track goal. I plan to keep the OK backpad and drill through it to mount the top straps through the firewall. I also "want" to get long eye bolts that I can bolt through my stock belts at the lower mounts, keep the stock belts, and clip in the lower belts for weekend AX duties.
Sound like an OK plan? Any PCA or SCCA rules to watch out for? What would youz guyz advize for harness brands and styles?? I want to spend $300 or less for a pair of black 5-point harnesses. How much better is the cam lock vs. latch? Pull up or pull down? I like the IMPACT Racing 5-pt adjustable latch and the G-Force 5-pt cam so far, these both fit my budget. (IMG:style_emoticons/default/beerchug.gif) |
| nebreitling |
Apr 10 2007, 07:02 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
i actually prefer the latch over the cam, but to each his own... if the belts are just for AX, you might consider finding a used harness that is out of date.
i don't know if it includes the hardware or not, but these are cheap: http://www.saferacer.com/prose5plalih.html |
ChrisNPDrider Adding 5-pt harnesses to my 914 Apr 10 2007, 04:51 PM
Dan (Almaden Valley)
I found myself really hangin on tight to the whee... Apr 10 2007, 05:00 PM
jgara962 I know it's not exactly what you are looking f... Apr 10 2007, 05:23 PM
ChrisNPDrider Dan - checked IOPort web site and liked the Auotpo... Apr 10 2007, 06:06 PM
Dan - checked IOPort web site and liked the Auotp... Apr 10 2007, 06:24 PM
gud plan! :)
meanw... Apr 10 2007, 07:12 PM
mudfoot76 I have the 5pt latch (pull down) belts from Impact... Apr 10 2007, 07:33 PM
911quest Remember the PCA rule is if the drivers seat has a... Apr 10 2007, 09:02 PM
nebreitling yeah, but you don't have to do PCA events. in... Apr 10 2007, 09:57 PM
jhadler I actually like the cam. But not all cam latches a... Apr 13 2007, 03:44 PM
ChrisNPDrider
I have the G-Force cam-lock in my car. Good, but ... Apr 13 2007, 04:29 PM
jhadler
I have the G-Force cam-lock in my car. Good, but... Apr 13 2007, 04:50 PM
Borderline Chris:
Get Trekkor to give you a ride in his car.... Apr 15 2007, 10:59 PM
woobn8r I use a 5 point 3" belt system with a "g... Apr 16 2007, 10:04 AM
but, for "real" racing there is only on... Apr 16 2007, 10:53 AM
ChrisNPDrider Bill - a ride with Trek was one of my first AX exp... Apr 16 2007, 07:15 PM
sean_v8_914 If I had to choose one VS the other for budget rea... Apr 17 2007, 11:50 AM
jhadler Keep in mind, that in lots of autox classes, harne... Apr 17 2007, 11:56 AM
sww914 I've instructed in and driven in a lot of cars... Apr 17 2007, 02:46 PM
sean_v8_914 PCA zone 8 does not take points for the seat. I un... Apr 19 2007, 12:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:15 PM |
