Name These Brakes, For mystery lovers |
bigkensteele |
Apr 12 2007, 09:38 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Quick story of origin. My cousin bought an old Beetle cab a few years back that had been converted to Porsche 5 lug. The fronts were a disc kit, and the rears were drilled drums. However, these rear brakes came with the car, and he gave them to me. He has no idea what kind of car they came from, and neither do I.
- Bolt spacing is same as Porsche 5 lug - Calipers are ATE, 3.75" spacing, single piston, no PN found - Hubs are 12 spline stamped Germany SHW 477 501 605 - Backing plates are stampted with a similar 477 xxx xxx number - Parking brake assembly similar to 911 inside disc - Spacing on 4 mount holes is 3.5" diagonal - Discs are vented, 11 3/8 (290mm) Given the design of the caliper, these appear to be old, like sixties old. Pics: |
bigkensteele |
Apr 13 2007, 08:54 AM
James, thanks for the link. Looking at the parts diagram, it would seem that these are indeed 944 brakes. That makes you, Eric and Dave the winners, or biggest nerds, depending on how you want to look at it.
NOW, the real question. Has anyone ever used 944 rears on a 914 to get the vented rotor and floating caliper??? |
davep |
Apr 13 2007, 09:43 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
NOW, the real question. Has anyone ever used 944 rears on a 914 to get the vented rotor and floating caliper??? Why? The vented brake setup that Eric and I sell is simple, easy, uses mostly stock components and pretty much bolts right up. It even keeps the stock parking brake. |
bigkensteele |
Apr 13 2007, 10:51 AM
NOW, the real question. Has anyone ever used 944 rears on a 914 to get the vented rotor and floating caliper??? Why? The vented brake setup that Eric and I sell is simple, easy, uses mostly stock components and pretty much bolts right up. It even keeps the stock parking brake. How thick are the hub spaces in the kits (how much closer will my tire be to my fender lip)? Looks like about 1/4". Does this require longer studs? Would it be feasible to machine the same amount off the caliper mounting tabs? |
Lo-Fi Version | Time is now: 10th June 2024 - 08:04 AM |
