Some Bucking at Low-end...then pulls like a mule, Trying to get all the bugs out--I need your help |
computers4kids |
Apr 14 2007, 09:32 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I need your help...I've got my transplanted djet 2ltr (76 de-smogged motor) in and running...and driving. I'm trying to get the motor running good but I'm having a problem with low rpms.
If I try to slowly accelerate the motor seems to "buck," hestitate until the motor reaches about 3,000 rpm then it's smooth sailing. However, if I put my foot into the pedal harder and run through the gears it pulls hard and strong like a mule....awesome. Below are some things I've done:
The only other symptom worth mentioning, is when I first start the motor when it is cold, the idle hunts quite a bit....like 1000 rpm...not to sure what that is all about. I did install a oem thermostat and the air flaps are working correctly. After it warms up the idle is fairly steady but a bit rough. Sorry for the long story....I need some ideas |
computers4kids |
Apr 15 2007, 07:27 PM
do you have your original temp sensor? measure its resistance (while cold) and compare with the new one. there is apparently more than 1 part # with different specs. when I replaced mine the resistance of the new was alot less and this caused bucking on accel especially when cold. I compensated with a 500 ohm resistor, but this is not really the proper solution if the right part can still be obtained. My '76 2.0 did the same- almost 20 years ago. I called George at AA, and he asked if I had a ballast resistor in series with the TS2. I originally had one, which I had removed since I couldn't find any reference for it. He told me to put it back in. I did, and it ran great and with no problems through '02 when I pulled it for its rebuild. Yes, I KNOW the ballast resistor isn't supposed to be in on a '76, but it worked. Good luck! Latest update... I threw in a 270 ohm resistor in series with my head temp sensor and it made a world of difference on cold startup....no hunting idle...fast idle then settled right down as it warmed up (aux valve closing). The resistor also improved my low end bucking quite a bit even after the car warmed-up...I guess this is telling me I was running my FI too lean?? Next, I want to get a air/fuel ration gauge and connect a variable pot to the head sensor and adjust for smoothest running at 2500 rpm (as suggested by Kjell Nelin article) or until CO is between 1.5-2.0%. Checked the throttle position switch and I'm getting exactly 20 clicks...and tried unplugging it and running without it...amazing how well the car still will run...just a bit more sluggish....anyway, it appears to be OK so I plugged it back in. I also advanced the timing a few more degrees which smoothed things out as well. Overall, I think I'm on the right track. I don't want to play with the ECU idle knob until I know by CO levels are correct via the head sensor. I'm getting closer and closer... (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 11:12 AM |
