If I try to slowly accelerate the motor seems to "buck," hestitate until the motor reaches about 3,000 rpm then it's smooth sailing. However, if I put my foot into the pedal harder and run through the gears it pulls hard and strong like a mule....awesome.
Below are some things I've done:
- valves adjusted while engine was cold .006 and .008(exhaust)
- Installed new petronix ignition
- Set timing at 27 degrees at 3500 rpm
- Completly removed and cleaned throttle body and blew out all the ports with carb cleaner
- Cleaned throttle position contacts (excellent condition) and adjusted idle and full throttle contacts using an ohm meter
- all injectors were serviced
- fuel pressure set and steady via gauge at 28lbs
- New plugs, rotor, cap...wires appear to be in good condition
- installed a rebuilt 043 MPS (Bleyseng)
- Checked for vaccum leaks
- Engine runs at 325-350 on CHT gauge
- New cylinder head temperature sensor
- New air cleaner
- adjusted the ECU....as I understand it...this is only an idle adjustment mixture....although the motor smells maybe a tad rich at idle
- Have not played with the trigger points (stock bosch dizzy)
The only other symptom worth mentioning, is when I first start the motor when it is cold, the idle hunts quite a bit....like 1000 rpm...not to sure what that is all about. I did install a oem thermostat and the air flaps are working correctly. After it warms up the idle is fairly steady but a bit rough.
Sorry for the long story....I need some ideas
