Some Bucking at Low-end...then pulls like a mule, Trying to get all the bugs out--I need your help |
computers4kids |
Apr 14 2007, 09:32 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I need your help...I've got my transplanted djet 2ltr (76 de-smogged motor) in and running...and driving. I'm trying to get the motor running good but I'm having a problem with low rpms.
If I try to slowly accelerate the motor seems to "buck," hestitate until the motor reaches about 3,000 rpm then it's smooth sailing. However, if I put my foot into the pedal harder and run through the gears it pulls hard and strong like a mule....awesome. Below are some things I've done:
The only other symptom worth mentioning, is when I first start the motor when it is cold, the idle hunts quite a bit....like 1000 rpm...not to sure what that is all about. I did install a oem thermostat and the air flaps are working correctly. After it warms up the idle is fairly steady but a bit rough. Sorry for the long story....I need some ideas |
Lo-Fi Version | Time is now: 19th May 2024 - 03:11 AM |
