rwjames |
Member ![]() ![]() Group: Members Posts: 326 Joined: 2-June 06 From: Montgomery, AL Member No.: 6,136 Region Association: South East States ![]() |
Could have been serious safety issue, but I guess I got lucky.
Decided to drive the '75 914 Saturday morning. Fired it up, backed it out of the garage, turned the steering wheel to pull down the driveway. A popping noise came from the front of the car as I'm still backing in reverse and the steering turns to crap. I get out of the car and one front tire is turning right while the other is turning left. I put the car up on jack stands and remove the steering rack cover. The tie rod came out of the steering rack and was just dangeling from the wheel side. This car has the turbo tie rods that were on the car when I purchased it from AA about 2 years ago. I have probably driven the car about 1500 miles since I have owned it with no signs of trouble with the tie rods or front suspension. Any ideas of how the tie rod could just pop out of the steering rack. The threads on the rod and inside the rack appear to be ok from what I can tell. Should I just remove the pin and nut from the wheel side and screw the tie rod back into the rack? Anything else I should look for? I assume I will also need to have the alignment checked? I feel lucky as this could have happend going into a corner at speed and the results would have been ugly. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/headbang.gif) |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Put some ass on it when you tighten the thing. Obviously the DAPO did not have any ass.
I use a pipe wrench to get a good torque on them. Some say use one of them fancy wrenches . I just use brute force. |
Lo-Fi Version | Time is now: 17th June 2024 - 06:52 AM |
