z-block and dial guage, for cam timing |
echocanyons |
Apr 15 2007, 02:36 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I need to pick up a few tools to be able to time my cams on my 6cyl. engine.
The z-block seems to be easy to find but I am having a bit of trouble finding a dial gauge. I am guessing it measures cam lift but in metric but what does it measure mm? Is there a preferred type that will function with the z-block? (IMG:style_emoticons/default/wavey.gif) |
burton73 |
Apr 16 2007, 12:23 PM
burton73 Group: Members Posts: 3,539 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have bought special tools from Pelican and from Ebay. Chain tensioners are Carrera set oil fed at $515. As the low price OEM German . I have the old castings from early 911 cases for chains and tensioners and the word is I need to machine those to fit the modern tensioners to fit in. I know I need to look at something when I get there. I have a 2.5 Engine with aluminum cases. What are you rebuilding?
Bob |
echocanyons |
Apr 16 2007, 01:13 PM
I will be installing rebuilt tensioners on my 3.0 soon but I will be doing a complete rebuild of my other 3.0 down the road.
It sucks that they both use different cam tools! Burton73, do you just need spacers or new boxes? |
echocanyons |
Apr 16 2007, 01:16 PM
I will be installing rebuilt tensioners on my 3.0 soon but I will be doing a complete rebuild of my other 3.0 down the road. It sucks that they both use different cam tools! Burton73, do you just need spacers or new boxes? I think someone posted that hydro tensioners for just over 400 dollars but I can't remember who (you may want to do a search). |
Justinp71 |
Apr 16 2007, 01:37 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I will be installing rebuilt tensioners on my 3.0 soon but I will be doing a complete rebuild of my other 3.0 down the road. It sucks that they both use different cam tools! Burton73, do you just need spacers or new boxes? I think someone posted that hydro tensioners for just over 400 dollars but I can't remember who (you may want to do a search). That was EBSracing.com for $490. Did you rebuild stock 901 chain tensioners? Did you do it yourself? I have a soft left side tensioner and I am not sure where I should go from here but $500 it way to much... |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:22 AM |
