Oil tank installation steps |
bcheney |
Apr 18 2007, 10:24 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
I have a OEM 914/6 Oil tank that I need to install into my conversion project. The car is a 75. Can anyone provide step by step instruction on how to install the tank? Just want to know the steps from someone who has completed this work so I can avoid mistakes. I have the 914/6 conversion guide from Auto Atlanta. However, it simply tells you to use the template they provide and install.
SLITS |
Apr 19 2007, 03:06 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Drill holes ..... slide tank in
make sure you angle the suction hose slightly towards the engine bay or it will hit the rocker panel. Oh yeah, put this hose on as you will not be able to get to it when the tank is installed. Also on later models ('73 up), there is apparently a piece of metal (seam) near the door striker plate on the inside of the fender well that may need grinding flush as it will interfere with the tank fully sliding into the fender well. I dunno, I converted a '70. Get a GOOD set of hole saws .... Harbor Freight's dulls the minute it touches metal. When you return them they tell you it is not for metal .... box dona say that. If you've drilled all the holes in the right places, ain't no thang! |
Lo-Fi Version | Time is now: 17th June 2024 - 10:01 AM |
